Windows 10: Problem with sound devices. After computer hibernate, I do not have sound, so I have to...
Discus and support Problem with sound devices. After computer hibernate, I do not have sound, so I have to... in Windows 10 Gaming to solve the problem; After computer hibernate, I do not have sound, so I have to restart the system to fix the problem.... Discussion in 'Windows 10 Gaming' started by Reynaldo Mejia, Mar 8, 2025 at 9:17 PM.
  1. Problem with sound devices. After computer hibernate, I do not have sound, so I have to...
  2. fireberd Win User
    Sound Quality
    One thing that sticks out from looking at your "My Computer" specs. You list "ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)" which suggests you do not have the correct sound hardware driver. Your motherboard has Realtek sound and the first step is to install the Realtek sound drivers. My ASUS also came with Sonic Studio 2 which is a sound enhancement package. Check the ASUS install disc to see if you have something similar.
    May not be a speaker problem.
  3. Sound problem
    Hello David,
    Method 1:
    Hardware Troubleshoot
    Windows 10 has a built-in troubleshooter to check and fix issues with Sound. I would suggest you to run this troubleshooter to check if the issue is with your Audio.
    Refer these steps:
    • Press Windows key +X, select Control panel.
    • Change the view by option on the top right to Large icons.
    • Click on troubleshooting and click on the view all option on the left panel.
    • Run the playing Audio troubleshooter.
    Method 2:
    Sound problems can be caused by cables that aren't connected properly, damaged drivers, incompatible drivers, sound settings, missing updates, and problems with your sound card.
    I request you to follow the below steps:
    Step 1: Uninstall the Sound card Drivers
    a. Press “Windows Logo” + “X” keys on the keyboard.
    b. Click on “Device Manager” from that list.
    c. Search for the Sound driver from the device list, right click on it and then select “Uninstall”. On the un-installation window, if you have an option: “Delete the driver software for this device” you may select that and then
    remove the corrupted drivers from the computer.
    d. Follow the on-screen instructions to complete it and the restart the computer if prompted.
    After the restart, please go ahead with the next steps to install the latest drivers and check if that resolves the issue.
    Update Driver Software from the Manufacturer’s website.
    Step 2: Go to the Computer or Sound Card manufacturer’s website and search for the latest Windows 10 drivers available for the Sound Card model and then install it by following the instructions given in the website.
    I also request you to follow the below article:
    Fix sound problems
    Fix sound or audio problems in Windows - Microsoft Support
    I hope this helps you. If you have any further query in future, feel free to contact us. We will be happy to help you.
    Amit(Kumar), Mar 8, 2025 at 9:20 PM
  4. Pavan_N Win User
    PROBLEM WITH SOUND
    Hi Emilio,
    Please answer these questions to assist you better.
    • Have you install pending Windows and driver updates?
    • Do you get any error message?
    • What Is the make and model of your computer?
    Follow the Microsoft article below and perform the troubleshooting steps suggested.
    Fix sound problems.
    Do let us know if you are able to get sound in your PC. Thank you.
  1. Problem with sound devices. After computer hibernate, I do not have sound, so I have to... - Similar Threads - Problem sound devices
  2. Problem with sound devices. After computer hibernate, I do not have sound, so I have to...
    Problem with sound devices. After computer hibernate, I do not have sound, so I have to...: After computer hibernate, I do not have sound, so I have to restart the system to fix the problem. https://answers.microsoft.com/en-us/windows/forum/all/problem-with-sound-devices-after-computer/3c4d6163-c542-49c2-833f-815000823f0d
  3. i have no sound on my computer.
    i have no sound on my computer.: i have a dell dimension 2400. it is missing the driver for the multimedia audio controller. The dell website gave me a list of drivers but none of them seemed to fit the bill. I am stuck what can I do to get sound? everything else works....
  4. i have no sound on my computer.
  5. I have no sound in games, but I do have sound in Windows 11
    I have no sound in games, but I do have sound in Windows 11: I am seeking assistance regarding ongoing audio issues on my Huawei MateBook 14 2024 model running Windows 11. While system sounds function correctly, youtube, spotify and other experiences have no issue, I experience no audio during gameplay across several games, including...
  6. I have no sound in games, but I do have sound in Windows 11
  7. i have problem with my sounds
    i have problem with my sounds: hello please kindly can you help me with my sounds because in my laptop dosnt work at all have a nice evening best regards https://answers.microsoft.com/en-us/windows/forum/all/i-have-problem-with-my-sounds/82a354bf-4573-4502-8acb-87018d169a10
  8. i have problem with my sounds
  9. I have problems with the sound
    I have problems with the sound: my sound buzzes after i buy a mic and plug it in, the sound started buzzing and i can't fix it, please i need help if you know anything about drivers or devices.Please help!...
  10. I have no sound.
    I have no sound.: My sound went out, and I can't update my drives. https://answers.microsoft.com/en-us/windows/forum/all/i-have-no-sound/b0215d41-57f4-449b-9fa8-845022ffd6f7
