Windows 10: Intermittent distortion problems with a Creative Sound Blaster Audigy Fx sound card on...
Discus and support Intermittent distortion problems with a Creative Sound Blaster Audigy Fx sound card on... in Windows 10 Software and Apps to solve the problem; To All,I recently started having intermittent distortion problems with a Sound Blaster Audigy Fx 5.1 PCLE sound card on Windows 11 24H2 Build... Discussion in 'Windows 10 Software and Apps' started by Steven Haymes, Mar 12, 2025.
  1. Intermittent distortion problems with a Creative Sound Blaster Audigy Fx sound card on...
    To All,I recently started having intermittent distortion problems with a Sound Blaster Audigy Fx 5.1 PCLE sound card on Windows 11 24H2 Build 26100.3476 when playing music CD's and also general system sounds. The sound will be good for several minutes and then it will be bad for several minutes and then the cycle repeats. The sound card is 9 years old and was moved from an old Windows 10 desktop to a new Windows 11 desktop about 6 months ago and worked fine up until about a week agIntermittent distortion problems with a Creative Sound Blaster Audigy Fx sound card on... o_On the hardware end, I removed and inspected the sound card and saw no obvious damage. I cleaned the output j
  2. AngelP Win User
    Driver Creative Sound Blaster Audigy 4 Pro. for Windows 10
    Hi, My Sound Blaster Audigy 4 Pro.
    I wanted to ask if there is Driver or something better and that works for the sound card Creative Sound Blaster Audigy 4 Pro.
    Here are the Driver for the Creative Sound Blaster Audigy 4 upgraded to Windows 10, but my Sound Card is the Audigy 4 Pro.:
    SBA4 SII PCDRV L02 3 01 0044.exe
    But for the Creative Sound Blaster Audigy 4 Pro, yet they are with older versions of drivers for Windows 7 and Windows Vista:
    SBAX PCDRV LB 2 18 0017.exe
    Try to install the drivers for the Creative Sound Blaster Audigy 4 "SBA4_SII_PCDRV_L02_3_01_0044.exe" but throws an error message that prevents hardware installation.
    The Driver of the Creative Sound Blaster Audigy 4 Pro. Not work well in Windows 10, new clean installation.
    What I have to do? I do not want to miss this fantastic audio card!
    What are the driver operating in this card "Creative Sound Blaster Audigy 4 Pro." For Windows10? *Think
    AngelP, Mar 12, 2025
  3. BulldogXX Win User
    Need basic sound card recommendation - Sound Blaster obsoleted by Windows 10 1803 update
    Are you sure that your computer doesn't have a sound chip on the motherboard? My aged Studio XPS 8100 has that.
    Creative (who bought SoundBlaster long ago) makes the
    Sound Blaster Audigy FX
    for only $40 on their website ... and you could probably pay less than that elsewhere.
    I remember when SoundBlaster owned PC audio. That was long ago. Now the sound chips on motherboards provides all the sound most people need. Today's sound cards are for special purposes like gaming. They do sound amazing.
    BulldogXX, Mar 12, 2025
  4. AngelP Win User
    Thanks Speakons, I will follow your advice, is absolutely right, while not miss what you have, better not touch
    Thanks to TairikuOkami, I dont know these drivers "not supported by Creative Labs", you tested this driver in any opportunity?
    Note well that my audio card is the Creative Sound Blaster Audigy 4 PRO is very different to the Creative Sound Blaster Audigy 4 Standart and have different internal processor, the page just says you mention Audigy 4 and do not specify this is a PRO or Standart PRO.
    I can take the risk?
    This is the Audigy 4 Standard:
    http://www.abclinuxu.cz/images/scree...-pro-52208.jpg
    This is Audigy 4 PRO:
    404 Página no encontrada
    http://www.guru3d.com/articles-pages...y-4-pro,1.html
  1. Intermittent distortion problems with a Creative Sound Blaster Audigy Fx sound card on... - Similar Threads - Intermittent distortion problems
  2. Intermittent distortion problems with a Creative Sound Blaster Audigy Fx sound card on...
    Intermittent distortion problems with a Creative Sound Blaster Audigy Fx sound card on...: To All,I recently started having intermittent distortion problems with a Sound Blaster Audigy Fx 5.1 PCLE sound card on Windows 11 24H2 Build 26100.3476 when playing music CD's and also general system sounds. The sound will be good for several minutes and then it will be bad...
  3. Creative sound blaster z not recognised
    Creative sound blaster z not recognised: [ATTACH] I bought a new Creative Soundblaster Z to overcome problems with the integrated sound card (the audio output was "heard" by the microphone). So i open the case and install it on the PCI Express X 1, restarted the pc but it wasn't working. In the device manager I...
  4. Creative sound blaster z not working
    Creative sound blaster z not working: [ATTACH] I bought a new Creative Soundblaster Z to overcome problems with the integrated sound card the audio output was "heard" by the microphone. So i open the case and install it on the PCI Express X 1, restarted the pc but it wasn't working. In the device manager I...
  5. Creative Sound Card
    Creative Sound Card: I just brought a Creative SB Audigy RX sound card, everything is find only the driver from creative web site is oudated. Anywhere i can find mod/hack/updated drivers ? Thanks. 168355
  6. After updating to Windows 10 2004 Creative Soundblaster Audigy Fx sound card is not working
    After updating to Windows 10 2004 Creative Soundblaster Audigy Fx sound card is not working: After updating to Windows 10 2004 Creative Soundblaster Audigy Fx sound card is not working. There is no sound my web browsers. I have tested this in both the latest versions of Mozilla Firefox and Microsoft Edge. When playing videos, the sound is significantly reduced...
  7. After updating to Windows 10 2004 Creative Soundblaster Audigy Fx sound card is not working
  8. Sound Blaster Audigy 2zs driver not working correctly ?
    Sound Blaster Audigy 2zs driver not working correctly ?: My Sound Blaster Audigy 2zs driver is not working correctly. It use to work. My checked my hardware in linux and Mac OS and it works fine. So the problem is with the Windows Driver. What is happening is that I get NO audio out put in Win-10-Pro But it works fine in...
  9. Audigy FX Problems
    Audigy FX Problems: Howdy! I bought a Creative Sound Blaster Audigy FX 5.1 Sound Card SB1570 a couple of years back and I never have been able to get it to work correctly in Win 8.1 or Win 10. It'll work just fine occasionally after a shutdown, but if I reboot again it'll stop and may not...
  10. Driver Creative Sound Blaster Audigy 4 Pro. for Windows 10
    Driver Creative Sound Blaster Audigy 4 Pro. for Windows 10: Hi, My Sound Blaster Audigy 4 Pro. I wanted to ask if there is Driver or something better and that works for the sound card Creative Sound Blaster Audigy 4 Pro. Here are the Driver for the Creative Sound Blaster Audigy 4 upgraded to Windows 10, but my Sound Card is the...
