Windows 10: Huge Battery Problem Only running on AC power
Discus and support Huge Battery Problem Only running on AC power in Windows 10 Gaming to solve the problem; I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8.... Discussion in 'Windows 10 Gaming' started by Mina Tamer, Sep 30, 2023.
  1. Huge Battery Problem Only running on AC power
    I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8. One day while I was doing this, the battery suddenly cut off and never worked again Keep in mind the battery is relatively new and not used or drained frequently, its been around for less than 4-5 years and It has ran perfectly. I went to Device Manager to see if i can disable and re-enable or Update the “Microsoft ACPI Compliant Control Method Battery” driver. Strangely enough, when I updated it, the status went from “No battery is detec
  2. Battery Won't Charge Fully
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    FreeBooter, Sep 30, 2023
  3. battery to AC power?
    How do I get my PC to run on AC power and not the battery when plugged in?
    PatriciaMock, Sep 30, 2023
  4. Huge Battery Problem Only running on AC power
    Step 1
    Step 2
    Step 3
  1. Huge Battery Problem Only running on AC power - Similar Threads - Huge Battery Problem
  2. AC power Problem
    AC power Problem: Laptop model = HP Pavilion 14-ce0510nd Standard configuration.OS = Windows 11To get the laptop to charge i first have to shutdown the laptop. Then connect the power plug.If i turn the laptop on it will remain charging or operate on AC.However, when the laptop is running and i...
  3. AC power Problem
    Huge Battery Problem Only running on AC power: I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8. One day while I was doing this, the battery suddenly cut off and never worked again Keep in mind the battery is relatively...
  5. Huge Battery Problem Only running on AC power
  6. How to use AC Power Adapter instead of battery
    How to use AC Power Adapter instead of battery: Hi,I have the *ASUS TUF F15 2021* I want to use this laptop while using the AC Power Adapter because it performs better than Battery mode while using the battery*So, is there a way to do that without decreasing the battery's lifespan?*...
  7. Battery not charging only works in AC power even battery is zero
    Battery not charging only works in AC power even battery is zero: My laptop is msi Bravo 15. I know about the msi dragon center's charging modes this is not about that. My laptops battery is not charging . It is initially at 44% when I know about this issue. When I connect the adaptor the laptop doesn't use the battery it automatically use...
  8. Battery not charging only works in AC power even battery is zero
  9. Laptop Only Running on AC Power
    Laptop Only Running on AC Power: I have a Toshiba Qosmio X75-A, recently I noticed that it is only running on AC power and not on the battery. The battery reports that it is fully charged. I replaced the battery with a brand new OEM battery and produced the same results. The laptop will not power on...
  10. running on ac instead of battery
    running on ac instead of battery: I have an HP laptop. How do I run On AC instead of battery? https://answers.microsoft.com/en-us/windows/forum/all/running-on-ac-instead-of-battery/b5edead9-83eb-43a5-97c0-0bc9603d4f40
