Windows 10: Battery stopped charging, Not recognized without power cable then charging 0% stuck
Discus and support Battery stopped charging, Not recognized without power cable then charging 0% stuck in Windows 10 Software and Apps to solve the problem; Hi, Please let me know if you think this is a hardware issue or a software issue. A few weeks ago my battery stopped charging randomly. I was not using... Discussion in 'Windows 10 Software and Apps' started by Allen B2, Sep 1, 2023.
  1. Allen B2 Win User
    Hi, Please let me know if you think this is a hardware issue or a software issue. A few weeks ago my battery stopped charging randomly. I was not using my computer in an abnormal way, and I do not believe I received any major windows updates right before that could have triggered the issue. The current symptoms I see are a battery symbol with an X through it when the charger isn't plugged in. When charger is plugged in, I see a battery charging symbol that never goes above 0% regardless of how long I keep charger connected with computer one or off. The battery regardless of the task bar ind
  2. CalvT Win User
    My battery stops charging randomly and then loses power
    I have a Lenovo E540 running Windows 10 x64. For quite a while now, I've been having problems with how the battery charges.
    When I plug it in, it will always start charging - maybe for only 30 seconds, but it will start charging. After x minutes (totally random) it will stop charging and say Plugged In, Battery Not Charging and the battery will start to drain from then on. As it is plugged in, I don't get any warnings as to the battery level, so quite often my laptop suddenly sleeps because of it.
    I've downloaded and installed all the latest drivers from Lenovo.
    I've tried various power adapters at various locations.
    There is some kind of pattern in when it stops, it generally is between:
    • 25% and 35%
    • 45% and 50%
    • 65% and 75%
    When it reaches these percentages, it will stop charging. By pulling the cable out then connecting it again, it will start charging again. If it's between those percentages, then often it will charge for only a couple of minutes. Once it stops charging, it will never charge again until disconnected and reconnected.
    The one thing I have found is that if I turn the laptop off, then connect the power, it will charge to 100% no problems.
    What can I do to fix this?
    If any additional info is needed, please let me know in the comments.
    Edits: I used to use it with Windows 8 and 8.1 (both x64) without any problems
    CalvT, Sep 1, 2023
  3. Battery Won't Charge Fully
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    Battery stopped charging, Not recognized without power cable then charging 0% stuck pbDp4sx.png
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    FreeBooter, Sep 1, 2023
  4. Battery stopped charging, Not recognized without power cable then charging 0% stuck
    Charging stuck at 70%
    Step 1
    Step 2
    Step 3
  1. Battery stopped charging, Not recognized without power cable then charging 0% stuck - Similar Threads - Battery stopped charging
  2. Plugged in but not charge the Battery and stuck at 0%
    Plugged in but not charge the Battery and stuck at 0%: I have lenovo ideapad gaming 3 intel i5 gtx 1650 laptop and I update windows 11 24h2 update. I use daily after update and work normally but one day I open laptop and working around 2 to 3 min and suddenly switch off . I plugged the charger and on the laptop . I saw my laptop...
  3. Plugged in but not charge the Battery and stuck at 0%
  4. Battery is Charging - Battery Status: 0% available plugged in, charging
    Battery is Charging - Battery Status: 0% available plugged in, charging: Subject: Assistance Needed: Battery Stuck at 0% Despite ChargingMessage:Hello Team,I’m encountering an issue with my device battery. Although it indicates that it’s charging, the battery level remains stuck at 0% and does not increase. If i try to unplug the charger, the...
  5. Battery is Charging - Battery Status: 0% available plugged in, charging
  6. Battery is Charging - Battery Status: 0% available plugged in, charging
  7. Battery is Charging - Battery Status: 0% available plugged in, charging
  8. Laptop charging but battery % is stuck at 0.
    Laptop charging but battery % is stuck at 0.: I recently sent my microsoft surface 5 laptop to be repaired because it wouldn’t charge and they sent it back saying there were no issues. I bought a new charger and now it will charge and turn on but the battery is stuck at 0% and will not increase. I’ve tried unplugging it,...
  9. Laptop charging but battery % is stuck at 0.
  10. Battery stopped charging, Not recognized without power cable then charging 0% stuck
    Battery stopped charging, Not recognized without power cable then charging 0% stuck: Hi, Please let me know if you think this is a hardware issue or a software issue. A few weeks ago my battery stopped charging randomly. I was not using my computer in an abnormal way, and I do not believe I received any major windows updates right before that could have...
