Windows 10: Audio and microphone low sound or no sound when using 3rd party applications
Discus and support Audio and microphone low sound or no sound when using 3rd party applications in Windows 10 Software and Apps to solve the problem; I recently bought a new laptop that came with Windows 11 installed NOT an upgrade. The sound and mic work fine using WIndows. However, any time I use a... Discussion in 'Windows 10 Software and Apps' started by CherylColeman1, Jan 8, 2022.
Audio and microphone low sound or no sound when using 3rd party applications - Similar Threads - Audio microphone low
No low end sound when using speakers.
in Windows 10 Software and AppsNo low end sound when using speakers.: Whenever i plug in my Yamaha HS4 Studio Monitors into my laptop the sound quality is very low, the low end is basically not there at all. This problem is true with headphones as well as the laptop speakers themselves. I have plugged my speakers and headphones into other... -
Low microphone voice sound
in Windows 10 CustomizationLow microphone voice sound: My microphone is good but it is barely recording voice sound i have also increased it to100 from properties, it only recognizes breathing air sound easily. I have tried updating driver from device manager and it says that I have already latest driver installedI have also... -
in Windows 10 GamingLow microphone voice sound: My microphone is good but it is barely recording voice sound i have also increased it to100 from properties, it only recognizes breathing air sound easily. I have tried updating driver from device manager and it says that I have already latest driver installedI have also... -
in Windows 10 Software and AppsLow microphone voice sound: My microphone is good but it is barely recording voice sound i have also increased it to100 from properties, it only recognizes breathing air sound easily. I have tried updating driver from device manager and it says that I have already latest driver installedI have also... -
Airpod sound extremely low on pc when microphone used
in Windows 10 GamingAirpod sound extremely low on pc when microphone used: I've noticed recently after some windows update that my Airpods pro gen 2 generate extremely low sound, but only when I'm on Zoom/Skype where also my microphone is being used. If I switch the use of the microphone from Airpod to some other mic, the sound volume on Airpods... -
in Windows 10 Software and AppsAirpod sound extremely low on pc when microphone used: I've noticed recently after some windows update that my Airpods pro gen 2 generate extremely low sound, but only when I'm on Zoom/Skype where also my microphone is being used. If I switch the use of the microphone from Airpod to some other mic, the sound volume on Airpods... -
in Windows 10 GamingAudio and microphone low sound or no sound when using 3rd party applications: I recently bought a new laptop that came with Windows 11 installed NOT an upgrade. The sound and mic work fine using WIndows. However, any time I use a Windows compatible application, or Zoom or another 3rd party application, the sound is inaudible and are hearing it as... -
Prevent 3rd Party Applications from Adjusting Microphone
in Windows 10 CustomizationPrevent 3rd Party Applications from Adjusting Microphone: I want Windows 10 to prevent 3rd Party Applications from adjusting the microphone gain.I spent a year troubleshooting this problem. Brought about 1000USD worth of mics, headphones, external mics trying to eliminate a ground loop hum and ambient noise from being picked up by... -
3rd party applications not detecting microphone.
in Windows 10 Drivers and Hardware3rd party applications not detecting microphone.: Hello, I recently did a full reset of my PC and my microphone stopped detecting any sound on 3rd party applications like browsers or Discord. When I try to record anything, silence is recorded. However it works perfectly fine on all native Windows apps and surprisingly...
